creeping idle when stopped
Captenor
My 89 240SX idle creeps up from just below 1000 RPM to 2000 RPM when stopped. If I shift to neutral when driving and coast at normal driving speeds, the idle stays at 1000. I have looked for obvious vacuum hose leaks around the smog things - EGR valve and a couple of others. Is there a better way to find vacuum leaks? Is there a specific smog type device that may have gone bad? I just replaced all 4 injectors. Is there any connection to that repair?
