You might want to start referring to the "stabilizer" as a sway bar or anti-roll bar. I'm not sure of many people who call it a stabilizer other than Stillen.supreman wrote:YOu might wanna check the 'stabillizer', whether it's factory spec or aftermarket. Sometimes, aftermarket stabilizer and its bushing(rubber parts) may create the sound you just described.....i guess...
I think I would refer to it as 'stabilizer' seeing as that is what many if not all Infiniti dealers refer to it as.Sentientbydesign wrote:
Problem is he probably needs to speak to the dealer about the problem with his vehicle.Sentientbydesign wrote:They refer to it as "Stabilizer Bar" and just about everybody on the forums refers to it as a "Sway bar".
It's fine if you want to communicate in a fashion that very few understand. I'm just offering some helpful suggestions
Both terms refer to the same suspension component. The bars use torsional force to link up independent suspension so that when one coil compresses the other is forced to as well which effectively reduces roll.pfarmer wrote:
Actually there really may be a difference in function as a stabilizer bar may well be design to control more than one condition. In engineering terms they may actually be two very different animals.
A sway bar would control left and right movement (sway), whereas a stabilizer bar often refers to a bar that controls 'sway' and side to side tilting (roll) and maybe even heaving, pitching, yawing, and/or surging.
Perry
Unless you go by definition and how Infiniti itself uses the term.Sentientbydesign wrote:
Stabilizer bar= sway bar = anti-sway bar = anti-roll bar
Is there a list of the TSBs along with the details? I ran into this with my Chrysler product and the only time I was able to actually find out the details was when I took it into the dealer for something else and specifically asked them about recalls (which there seemed to be one most of the time).Neovalentine wrote:Ok so now that we've throughly gone through how to define the sway/stablizer bar. I'm guessing this sound has to do with the TSB on this car for creeking rear axels?
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
