Creaks and Rattles
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
jakenbake
Car: 2009 Infiniti EX35
I love this car...But holy creaks and rattles Batman!
Has anyone had a noise that almost sounds like a hole in the muffler or a plastic plate vibrating on something? It only happens at start up and only very occasionally (maybe once or twice in a month). It gets a little little louder as I start to accelerate but disappears when I hit about 10 MPH and then it is gone for a month or so again. Normally I just kind of deal with it since it doesn't happen often...but it is awfully embarrassing when a friend is in the car and they point it out.
NJGuy
Car: 2008 Infiniti EX35 Journey AWD
I've got a low pitch plastic rattling noise in my EX, but I think I know the culprit. It's probably related to my engine splash shield, which has a long crack across it. There's also one bolt for the splash shield that's stuck to the metal clip, so when one tries to remove it they both spin together. I just chalk it up to the age of the car and the Northeast weather.
It sounds like you might have to do a lot of investigating before you find the source of the rattle. I think I have a better and easier solution. You upgraded your sound system, right? Just take advantage of the money and effort you invested there, and turn up the volume! :band: :badger ;)
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
