APCdude »
https://forums.nicoclub.com/apcdude-u14161.html
Fri Jun 16, 2006 9:38 am
Hello all,
I am having trouble locating the source of a creaking sound that appears when braking under 10mph on the front passenger side. It doesn't always show up, but lately it has been almost all the time.
It sounds kind of like a mix of front end suspension creaking and kind of like the rotor is slipping in the pads. Strange sound...
Exactly 6 months ago I replaced the rotors and brake pads, and the system is bled well. All of the suspension parts look fine, and all of the bushings around the wheel were replaced about 2 years ago.
A bit earlier I took off the caliper and inspected the rotor and caliper, which checked out fine. Also I took off the brake assembly and rotated the wheel bearing, which seemed perfectly fine. The only weird thing is that when turning the rotor by hand when the brake assembly and caliper are on, there is a rough spot of friction for about 1/4 of the rotor. However, the pads are new and even and the rotors are new and do not look warped as well.
What on earth could this be?
