MnM 35x »
https://forums.nicoclub.com/mnm-35x-u225495.html
Sat Sep 21, 2013 7:41 am
I had my pads changed and rotors turned a year ago and noticed there was a slight creak on the drivers side rear wheel. The noise is not continuous as some days it's completely quiet and other days very loud. The noise occurs when pressing and depressing the brake pedal at any speed including being completely stopped.
My thoughts are the rotor is creaking as the caliper presses against it. Although it appears the rotor on the creaky side is thicker than the one on the passenger side. One mechanic thinks it's the caliper itself and it needs to be replaced. Has anyone experienced this issue or have any suggestions?
I don't why the problem occurred after having rotors turned and pads replaced.
