Creaking Altima Coupe
All things Altima Coupe.
Chicago Coupe
Car: 2008 Altima Coupe 3.5 SE Dark Slate
Hey y'all, I posted a video on YouTube that I'd like you to listen to and let me know what you think. There's not much to look at, but the creaking/knocking/tapping sound is there. It starts out 11 seconds in, and comes and goes after that. You may need to listen with headphones on in a quiet room, but anyway it should be apparent if you listen closely. Any thoughts on what it could be? I'm not mechanically inclined enough to start taking things apart to isolate the noise, but I need some ideas on what could be causing it. It sounds like it's originating from either the console or from one or both of the front seats. All I know is that it's annoying as all get out!
Here's the link: http://www.youtube.com/watch?v=O0vwWroPV9U
If you were in my shoes and it was your new coupe, what would you do - take it to the dealer, or just crank up the stereo and ignore it?
Scandinavian Flick
Car: 2008 Nissan Altima Coupe 3.5SE
sounds haunted,
id take it to the dealer for an exorcism
Chicago Coupe
Scandinavian Flick wrote:sounds haunted,
I was just thinking the same thing. It does sound eerie.
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
It's not coming from the center armrest area? I think most of us have that creaking.....
Chicago Coupe
SHIFT_COUPE wrote:It's not coming from the center armrest area? I think most of us have that creaking.....
Yes! It does sound like it's coming from that area. I guess if it's normal, I can live with it.
johnnyplano
Car: '08 Coupe
Check the seat belt on the passenger side. It has a tendency to click back and forth between the side pillar and the seat. The seat belt guide on the side pillar is on a little positional thingy (technical term) that will snap into the forward position. If you position the belt guide in the forward position and adjust the passenger seat a little, you may lose the sound.
