CRC now makes MAF cleaner
Falkdesigns
Car: 1998 Q45t ~ EXE
Just saw this in the "new products" in Grassroots Motorsports, gonna get some as soon as it's on the shelf. CRC Mass Air Flow Sensor Cleaner is what the label says. The article says it can remove drit, oil and contaminants w/o damage to the wires or housing. It's safe for plastics and dries quickly. $5.99 a can. Just thought you guys would be happy to see this.
Awesome!
squeefoo
Car: 1990 Infiniti Q45
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
I'd like to see an MSDS.
yodawill2000
Car: 94 Infiniti J30
What do you guys use now ?I thought contact cleaner and some dielectric grease would do the trick .. No ??
nchopp
yodawill2000 wrote:What do you guys use now ?I thought contact cleaner and some dielectric grease would do the trick .. No ??
Yes, that works too. Pretty much any electrical parts cleaner will do the job.
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
I used this stuff, also made by CRC...
squeefoo
1999 Infiniti I30
Hey ! That's my avatar in the background of ozzie!'s pic!
I'm immortal now... :D
goody90q45
Car: 1992 Infiniti Q45 (sold)
Ozzie- You've created a monster!
Louis Cyphier
Car: 1999 Q45
theres a nice easy way to clean VW's MAF. Get good rubbing isopropyl alcohol. put about 2-3" of alcohol in a zip-lock bag, put the MAf in the bag and swish it around lightly.
remove it and allow it to air dry. use dielectric grease on contact points and re-install. install and call it quits.
dont know if this car be done with a Q MAF, but if someone has a extra its worth a try.
Q451990
I think there's some confusion here about cleaning the MAF... contact cleaner and dielectric grease and all. I would use the contact cleaner and dielectric on the electrical connections - but not on the screen and sensor itself.
Many contact cleaners have a very light lubricant built in - so you don't want that coating the sensor (remember the problems with oiled filters). I have used brake parts cleaner in the past for the sensor and screen...seems to work well. That said something designed specifically for it sounds better. I always wondered if brake parts cleaner might be a bit harsh.
Heath
DrewQ45
I just spray mine with brake parts cleaner and never mess with the contacts. Seems to work well for the job... it dries away fast and clean.
if you use contacts cleaner you want to make sure it says "leaves no residue" like on Ozzie's can above.
Falkdesigns
Grassroots Motorsports wrote: Around these parts, we use brake cleaner, or its fun, flammable cousin, carburetor cleaner, for just about everything under the sun.....
As good as these two products are, they can be a little harsh on the delicate electronics and fragile plastic. To solve that problem, CRC Industries has just released .... Their Mass Air Flow Sensor Cleaner is a safe and effective alternative to riskier methods of MAF sensor cleaning.
Most of you that use brake or carb cleaners are probably using CRC anyhow, and it's only $5.99 a can, "certainly cheaper than a new MAF sensor". I'm gonna check Pep Boys this weekend.
BigWill
Car: Gone, but not forgotten-2004 G35 Coupe-5AT-Graphite Now-2008 Black Saphire IS 250
squeefoo wrote:I'd like to see an MSDS.
Here's the company's product description:
http://www.crcindustries.com/a...0&S=Y
And the MSDS from their website:
http://www.crcindustries.com/faxdocs/msds/5110.pdf
It is available all over the place online.
Thanks for the heads-up Kevin. Having a JWT POP Charger, I have been thinking about cleaning my MAF for a while now.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
I tried this stuff in the black and red can...it worked well for me.
Ozzie
'06 MK5 Golf tdi
DrewQ45 wrote:I just spray mine with brake parts cleaner and never mess with the contacts. Seems to work well for the job... it dries away fast and clean.
You actually studied the pic close enough to read that??????
I am impressed!
(And yes, it leaves NO residue! Cleans the screen, probe, wires...... EVERYTHING without a problem)
