ayjay »
https://forums.nicoclub.com/ayjay-u5495.html
Tue Apr 01, 2003 9:53 pm
ok this has happened twice now, where it will be raining and when i hit a deep puddle it feels as if my wheel is going to fall off...
the first time it happened, i hit a deep puddle (approx. 3" deep) with the right front tire... i got this super crazy vibration, almost as if i had a flat tire, except it didn't pull to one side, and that is the only reason i knew it wasn't a flat while i continued driving...
the second time, i hit a puddle with the left front tire, and i got the same feeling, but from the left side obviously... it almost feels like it comes from behind the front tires...
both times, i continued to drive cautiously until gradually the feeling went away... as if water gets into something (definitely rotational) and then eventually leaks out and goes back to normal...
anyone know what the problem is?
