Crazy Screeching!
21nemesis
Car: 1993 240SX SE
I'm having an issue with something that needs to be greased. On cold starts something in the engine bay is screeching like CRAZY! When I rev the car up, it goes away, but the the screeching will come back in the evening, when it's cooler, at complete stop. Last weekend I did the oil change, and while under the car I took some WD-40 the all the pulleys, but still the problem persists. As long, as the car RPMs are above 1K, then there is no screeching. Any ideas on what it could be? I'm planning on taking it to Nissan tomorrow to have it diagnosed. So, should I not find a resolution with your guy's advise, I shall report back.
Thanks in advance!
S13_RB25
Car: A 240 but no RB yet!
Well is it coming from front of the engine?? Cause my water pump is making a noise, not screeching as you stated! I think the bearing are gone for mines but it could be that or something...
Feadz
Car: 91 240sx KA-T, 09 G37x
My alternator belt used to screech pretty loud on start ups and when it was cold outside. Maybe you need new belts?
21nemesis
Car: 1993 240SX SE
S13_RB25 wrote:Well is it coming from front of the engine?? Cause my water pump is making a noise, not screeching as you stated! I think the bearing are gone for mines but it could be that or something...
The front, sounds like it.
Feadz wrote:My alternator belt used to screech pretty loud on start ups and when it was cold outside. Maybe you need new belts?
That's what I'm thinking as well.
LoserCard
Car: Forest Green 1993 240SX SE Fastback
Come on this is like Car Maintenance 101, screeching sounds mean old worn out accessory belts. I am pretty sure nothing else makes a "screeching" noise in the engine bay.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
And lubing the belts makes them slip more... belts, adjustment or tensioner
Mercury_Hg
Car: 1993 240SX Coupe
OutToWinPAHC wrote:And lubing the belts makes them slip more... belts, adjustment or tensioner
This.
Have you messed with liquids or anything? Like gotten wiper washer fluid or coolant or oil on the belts?
If it's a newer belt, I'd tighten it (if applicable), or replace it.
