crazy k24e :/
LV240s.ex
Car: 89 ka-det Pig
I recently bought a piggy and my problem(which I can't find **** about) is that after like 45 mins. of driving, it start dieying!?? the gas tank picks up hella pressure, you can hear it wheezing out, even with a new cap. and like once it turns off, I can started again after two tries, but at the same time if I've been running the **** out of it, once it dies it wont start till it cools down. any ideas??
btw the previous owner said it was the fuel pump!?
funigui
Car: I HAD a 1991 240sx coupe. woked NA motor. ran like 14.5 ish. blew it up @ 140 after an ECU reflash.
do you smell gas? if you do it sounds like a fuel problem for sure. maybe bad fpr? orrr i had something simmilar wen i had bad injectors. kep playing with it.
