ginostef »
https://forums.nicoclub.com/ginostef-u13722.html
Thu Feb 19, 2004 11:56 am
Try removing the battery cable + and leave it for at least 15 to 20 minutes. Then come back and hook it back up, start and drive it. What we just did is clear the ECU of learned patterns and let it go back to the base installed map. If you have had IAA or IACV problems - this will do it so long as the IACV has been fixed! Mine did this habitually when warm and the only thing that fixed it was replacing the IACV, clearing the ECU, and then adjusting the IACV per the book (mine did not need any adjustment - came up 700rpm once replaced). The "hunting" idle happens a lot with this ECU/IACV. The one other slim chance would be a vacuum leak somewhere - those usually cause surges at strange times. Good luck!
