kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Mon Jul 26, 2010 10:49 am
Unfortunately this is always a much more intensive and difficult procedure than you'd think, one big reason is the computer programming, modern vehciles have an Engine Control Unit (ECU) and Transmission Control Module (TCM), each of which are precisely programmed to work with the specific engine and transmission of your vehicle. The TCM would not be compatible with a manual trans, so it would either have to be reprogrammed or replaced.
Then there is the phycial/mechanical issues, there is no guarantee that a manual trans will simploy bolt on, but I can't say for sure one way or another. This is such a complex and in-depth process you'd have to do a lot of research. Unfortunatley, the Quest is not a typcial vehicle that people make serious mods or alterations to so I don't think there will be much info. here, but if you had a 240SX for example, then you'd have more info. than you'd know what to do with!
But don't let me discourage you, I just wanted to let you know that this is a huge project and will requrie lots of cash and time, and you may be the first to try this so input and support will be limited. But I'd recommend talking to a good mechanic who is interested in the project and willing to do the intital research to determine if it may be possible.
Let us know how it works out!
