turbo98_240sx »
https://forums.nicoclub.com/turbo98-240sx-u16531.html
Fri Jul 15, 2005 4:32 am
ok I was sitting in my cubical and thought up something crazy, a turbo that was spooled by the oil flow through the center part. Well it wouldn't be completely spooled by it but for a bigger turbo to help aid in spooling it up. Am I on crack? because I thought some one would have thought of this b4 but I can't find any info to see if its been done/attempted/discussed, My though was that the oil would not only lube the turbo but have groves in the center house shaft of the turbo that would aid in spooling........the only problem I foresee is that it *might* reduce the top end of the turbo by creating a "drag" on the shaft because the shaft is spinning faster then the oil would be "pushing" it, I can think of several ways this could alternately be done and wouldn't have to be on the shaft itself, but would require way more knowledge then I have, the other way was through a gear system that was driven b4 the shaft (by oil) and once the pressure of the exhaust built up enough would "disengage" the oil gear. I realize that oil pressure would be critical but the rewards could be worth the effort. Any comments on this would help as I found nothing, but this seems like it wouldn't be a new Idea and someone somewhere would have thought this up and attempted some thing like it. Let me know what you think.
