I think that's how most single vehicle accidents occur. Can't get too confident or complacent. ABS might have helped but I hate to tell you that wouldn't have solved your problems completely. Have to adjust your driving to the conditions no matter how familiar you are with the road. Remember, ABS didn't exist for many many years. People got along fine without it. This year's Monaco GP (Formula 1, few weekends ago) most of the drivers averaged 170 mph on a very wet and tight urban street course with no traction control.The Edge wrote:The roadway was wet but i've traveled this road many times before.
Driving a motorcycle is totally different. A motorcycle is rear wheel driven and down shifting is slowing the rear wheel without locking it up (like brakes can), while maintaining good steering. The Versa being front wheel drive will only make the skid worse if downshifted too aggressively. When downshifting a front wheel drive car, you take a greater risk of losing your steering ability.matttail wrote:those of you who are saying you should not down shift to slow a car down, have you ever driven stick? And what would you have done differently? It's just stupid to say don't and not give us an explanation.
Down shifting is a great way to slow the vehicle down, it's just not as fast as your breaks.
Not that the versa is a Motorcycle, but this is what you do for motorcycles too.
Sheesh, take it easy. Most of this info can be found via Google.matttail wrote:those of you who are saying you should not down shift to slow a car down, have you ever driven stick? And what would you have done differently? It's just stupid to say don't and not give us an explanation.
Down shifting to slow the car down is OK if you really know what you're doing (as opposed to think you know what you're doing). I usually don't compression brake because worn brakes are much cheaper to replace than the engine or transmission. The only time I compression brake is when I'm really attacking a corner in the dry. I never compression brake in emergency situations. Brakes are more effective.
More on topic... Think weight transfer. On a FWD car, if you don't down shift smoothly (rev-match), you can cause the car to buck due to mismatch between engine speed and vehicle speed. Ever let the clutch out to soon or abruptly while down shifting? This bucking can unload the rear causing the rear tires to break loose which could lead to oversteer when you're in mid-turn. And if you're not ready to control or counter the oversteer, you'll end up overcorrecting back and forth playing catch-up (fish-tailing). Better tires help, but every tire no matter how sticky they are still have their limits of adhesion.
If you were on a track with room to play with, you'd want to roll on the gas smoothly and let the rears trail and settle to pull out of the fish-tailing. On the street, there may not be enough room to do this. In emergency situation like OP's story, you'd have to be a master to rev-match and do everything else I mentioned instinctively in a short amount of time. It can be a handful.
Without traction control, the last thing you should do in the wet is to jam on the brakes or attempt to shed speed abruptly in mid-corner. Smoothness is the key and a good habit to have even in dry. Also, to go through corners fast, your entry speed is not as important as your exit speed. Entering a corner too fast will most likely cause you to exit slow (because you've F'ed up!)
General rule of thumb: Be smoooooth. Do most of your slowing/braking before you start to turn, trail break as you turn towards the apex, then smoothly roll on the power to exit.
Modified by feloniousmonk at 12:09 AM 6/12/2008
I don't know about where you live, but it's illegal where I live to back INTO your driveway unless you live on a private road. It's also illegal to back into parking stalls, but people ignore that all the time here, too.Driving Instructor wrote:Yesterday, I was walking and my neighbor almost ran me over...... how many people drive in their driveways and back out....... YOU ARE LAZY.
YUPbucksnort wrote:Did you have the crap stock tires on?
Honestly, I am amazed that you don't teach your students basic car control in addition to avoidance. Yes, basic. Every licensed driver aught to know how to get out of a skid. They might not ever put the skill to use, but like the saying goes "never say never".Driving Instructor wrote:I don't teach what to do when you get into a skid, I teach how to avoid it.
Sorry and I don't mean to be an a**, but is it possible to request better use of punctuation? Your posts are incredibly difficult to read.
Bad bad advice - applying hand brakes ruin the balance of the brake system and will increase the chances of losing control.Vahagn23 wrote:You got to learn how to tap the breaks. I tap my breaks on rainy and snow weather. Better than ABS. On a sharp curve you cant slam breaks, especially on rain, its obvious your cars gona start sliding. Did you try pulling the hand break as well?
