Postby
magus0216 »
https://forums.nicoclub.com/magus0216-u15199.htmlFri Sep 17, 2004 7:58 am
The previous owner of my 93 240 got a really crappy tint job, maybe DIY. Its starting to ripple and just plain look ****ty. What should I use to get it all off? Peel it off then use some goo-gone or is there a better way?
Postby
Silvia007 »
https://forums.nicoclub.com/silvia007-u255.htmlFri Sep 17, 2004 8:20 am
Yeah peel it off slowly then go to a auto store and pick up this stuff made by 3M that takes off tree sap and such, it works really well on sticky substances.
Postby
D1SR240 »
https://forums.nicoclub.com/d1sr240-u9505.htmlFri Sep 17, 2004 9:11 am
i took mine of with some stuff my dad brought from work, but i think i cut a defroster line cuz now it doesn't work. Speaking of tint, does anyone know how much a good tint job costs?
Postby
Drift Machine »
https://forums.nicoclub.com/drift-machine-u201.htmlFri Sep 17, 2004 11:00 am
I removed my crappy tint, it was purple when i bought the car. By just heating up the tint with a hair dryer then using a razor blade to get up a corner and then I would just peel. It wouldn't always come off in the biggest chunks so it took a while. Then to get the glue off I just used rubbing alcohol and scrapped it off with a brush. Though I didn't really need to take care of my rear defroster because it already didn't work before I removed the tint. Shouldn't take you more then an afternoon.
If you screw up your rear defroster lines, you can find the gap w/ a multimeter and then fill it in w/ some conductive paint. There's a section on how to do it in the FSM.
D1SR240 wrote:i took mine of with some stuff my dad brought from work, but i think i cut a defroster line cuz now it doesn't work. Speaking of tint, does anyone know how much a good tint job costs?
Postby
rno240 »
https://forums.nicoclub.com/rno240-u17664.htmlSun Sep 19, 2004 8:28 am
I used this tuff called Goof Off that I got at Lowe's for about $6. I didn't even use a whole bottle. You better be ready for some sore arms though, it takes a while.
For the defroster lines, I got a little kit from JC Whitney for $5. It's the conductive paint and includes a guide to make sure the lines are straight.
Postby
MECPInstaller »
https://forums.nicoclub.com/mecpinstaller-u9687.htmlSun Sep 19, 2004 10:51 am
your quarter windows are pretty easy to tint for both s13 and 14. I did my driver's and passenger side windows and they were alittle screwy at first. First time i did i ended up scrapping the drivers window and redoing it. I wouldn't even attempt the rear glass myself but I've had my system in the backseat and can't really reach the window. Now if you could pop the rear glass out so gravity doesn't get its way with the tint it would be alot easier.
