crappy low rpm
Frankenstien93
Car: Nissan 240sx SE
my car runs like crap at anything under 2000rpm idle revs and will eventually die and if im holding a constant speed at anything under 2g it will lurch like hell. the vacuum gauge will go from 20 to 10 and bounce around in there but when i hit the gas it steady and if im over 2g it will sit at -20 i think the o2 sensor might be bad but im not sure as i have not gotten it to a scanner to see.
93 KADETstock fuel system8psi T3/T4fmic
Frankenstien93
has anyone had this problem before?
caspers_240
Car: 91 s13 fastback
I have the same problem. just droped in an 97 engine into my 91 and the bottom end sux... bad. 0-60=three days 60-115=right now
what start the problem for you? any changes, vac lines too hot and melted? anything different? i know i have to fix a gap (yes, very bad leak) between the manifold and the downpipe, maybe tune timing a little too?
DammitBobby
Car: S13 91 KA24DET
Anything under 20 vacuum at idle you need to look for an a air leak.
Try this first and let us know your results.zerothread?id=113785
fabio420
Car: 1995 nissan 240sx se
check the compression on your cylynders
KATwo40
Car: 1993 240sx KA-T
Sounds like a small intercooler pipe leak, or perhaps a very dirty IACV.
You can pull the hose off that little tube that sticks out from under the intake manifold next to the throttlebody. Fill that thing nearly full with throttlebody cleaner, re-attach the hose and start the car. It'll be very hard to start at first, then chug like a coal burning steam engine. After it clears out, see how it idles.
Chezedik
Car: 1991 Nissan 240sx
+1 for boost leak
Florida240sx
Thinking leak as well.
