Crappy E-brake??
(Q)240
Car: 92 240sx s13 Coupe
hey I have a 92 s13 Coupe & my e-brake wont lock when the car is moving & wont lock the rear tires... it only slows it down but barley... its usless... it only stops it from rolling when its in neutral... what can i do to make it lock while the car s moving?? Or whats Wrong With It?? Help Plz..
Thanks!
Modified by (Q)240 at 2:07 AM 8/2/2007
240hawaii
How far does the lever come up? maybe it needs adjustment.
Clearalbino
There is an adjustment screw in the e-brake lever. From what i remember i think its a 10 or 8mm.
1.lift the shift lever as high as possible. there should be a hole on the underside of the boot2. 10mm or 8mm and adjust to personal preference or FSM specs.
(Q)240
it comes up all the way.... just wont lock....but i will look under to see if i can see the screw
slidethe40
Car: 1992 nissan 240sx
wont lock the wheels up? or the lever wont lock? there is a spring alot of people take out for sweet drifting .
nwmrkt
Car: S13
is there a stainless steel line you can buy for the ebrake?
180fan
Car: 89 fastback
won't make too much of a difference to use a stainless steel hand brake line...
BoostGetsULaid
Car: Sileighty Sr20, S14 Kouki
ya sure you have some pad left on your back brakes? and if so use the 10 mm deep socket it under your e-brake lever and adjust it.
-Pull e-brake as high as possible-on the buttom of the e-brake lever. on the side facing the front of the car there should be a a little whole you can stick things into in this case you stick a deep socket in it. and adjust to your liking :-D
fearlife87
Car: 1989 nissan 240sx
lol, if you dont have pad, you hear it everytime you push the brakes, lol, i have done this. you should be able to tighten up the cable right?
BoostGetsULaid
yeah he should be able to.... i think he cant find it tho. if ya really seriously cant find it leave a little post and ill run out to my broke @$$ piece of junk sitting in my garage that i call a 240 and take a picture with my other piece of crap i call my cell phone
(Q)240
ALRIGHT GUYS THANKS ALOT IT WAS JUST THAT I HAD TO TIGHTEN THE SCREW NO MY WHEELS LOCK AND MY CARS SLIDES... LOL THANKS!
