freethinker wrote:Ok, I dont know what's in your pipe bro, but you need to quit smokin it. Curb weight is the weight of the vehicle, period. Some manufacturers quote it with fuel, some without. It is NOT a torque or spring rate. My car weighs 3020lbs. That is the curb weight, end of discussion.
Sean D.
3020lbs? what you got in their... your mom?thats at least 200 lbs over the heaviest 240
listen up 'constrictedthinker'... you may be the type that just gets springs... heat them.. the cut them... if you take the spring and straighten it out you have over 5 feet of it... if your car weighs over 3000 lbs then you assume that weight is distributed over the four suspension towers (obviously your cars weight isnt relied on one tire)
when you take a turn you cars weight goes to one side... but not all the weight depending on how low the car is plus tons of other factors defining center of gravityyour springs retract giving resistance... if your springs retract until they are touching coil to coil then that 100% resistance used... but that doesnt happen.. unless of course they're the ones on your car where they are completely destroyed from heat and shortened by cutting a couple coils off to 'slam' your car
2 suspension towers on each side... percentage of retraction gives you the percent of weight its holding (look on the box of your springs and it'll tell you how many lbs of resistance he can withstand)
take your cars weight and multiply it by the percent of resistance your spring gives
so lets just say your springs un coiled it 5 feet... and your car is 3000 lbs... between two springs combined you should have the resistance of at least half of 3000... 1500 lbs... each spring at 750lbs... if your spring resistance can withstand that then you have pretty damn good springs... but since your springs NEVER touch coil to coil you never use 100% of the springs resistance... so lets just say your springs retract half that 375lbs
now like i said... my springs coming around a turn probably do 270lbs/ft Eibach Sportline... i assume that you're ignorant to believe whenever you see lbs/ft it would always relate to torque..
