Structure240sx »
https://forums.nicoclub.com/structure240sx-u1949.html
Tue Sep 13, 2005 8:01 pm
on the other 2 cars, not mine yes. i brought them down to about -25% in the hi map in boost.
the way jwt usually works with timing, as far as a dohc (all i have expereince with). is the timing at full boost goes to 14-16 degrees then ramps up to 17-19 degrees by redline (less air flow/power dropping off)
it has always stayed within this limit. either way i would do anything you could to get a timing scanner of some sort to confirm the timing yourself, there has been known to be problems with some tunned ecu's
