Cranky but no starty, RB20 in S13.
foulplay
Car: 1992 S13 Fastback
All right here is what I got, the motor cranks but does not start. Followed wiring how-tos to the T from the stickies and racebread. I can hear the fuel pump kick on, and the two green relays on P/S under dash work. The red light on the ECU comes on when I turn the key.
I was searching earlier and came across this:zerothread?id=202146Upon reading it I read that the ECU needed to be grounded and not laying on the carpet. So I bolted it up to get it off the carpet, hoping that this would be the problem but still no start.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Do you have spark?Do you have the fuel lines hooked up correctly?Check for fuel pressureCheck if the injectors are firing
foulplay
The fuel lines, I have the pressure line going to the top.
How can I check to see if injectors are firing?How can I check to for spark? Its not like my KA where I can just pull the plug wire.
Sil240
Pull the coil paks and plugs.Put the plugs in the packs and spin the CAS.If no Spark setup the threads of the plugs so they can touch ground either through a wrench or whatever.
injectors find a Noid light and stick it in the harnesses. If they light up then pull the injectors and test them on the battery.
Get the FSM if you dont have it.
foulplay
Thank you for your help. I had the fuel line connected to the return. RB starts and idles. Now to finish.
Sil240
HAha Nice easy problem
Now I demand Vids.Action ones too!!!
Good luck
foulplay
Here ya gohttp://www.youtube.com/watch?v=oUuP98kgaF0
theres not much action, but it runs!
Sil240
Nice sounds exactly like mine. lol
And same like mine, runs but there's no action :-(
