ED03GV_626 »
https://forums.nicoclub.com/ed03gv-626-u238052.html
Tue Jul 01, 2014 9:27 pm
this is just difficult because the crank won't rotate down to TDC, so I basically have to align the belt and sprockets offset of the back-covers.
so just to final-check... in my case, the dot on the crank gear won't go past, and is pointing at about 2:00, slightly above the oil pan notch.
this means that i will have to carefully rotate the cam-gears CCW, and align the belt and gear at a position that is slightly to the left of the valve resting position (away from where the back plate marks are) correct? to ensure that the pistons and valves are corresponding to the cranks current 2:00 position?
