biosehnsucht wrote:grr i may have to invest in an air cutoff gizmo and do it like f s t caz did...
Sometimes even that doesn't work...
The Z32 has a similar cog, but its THICKER... imagine that. Anyway, I've had to cut a number off in my time, but the last one that was a pain, I WD'd, torched, pryed, hit, banged, pulled (tried to pull w/ a puller), cut (with a cutter like my brother f s t caz did), and even air hammered it... and it FINALLY broke loose... but I fuggered the guys oil pump cover... argh... =( And that was from the PRY BAR!!! Not anything else... go figure. Sorry to hear about your issues, but even the most tried and true methods don't always work.
