Crankshaft
deej-79
Car: Cars, and more cars
After searching and looking around I will guess that the CA18DE crankshaft and the CA18DET crankshaft are the same. Can anyone confirm this?
Also can anyone point me in a direction to possibly buy or have a Crankshaft balanced?
Thanks much,Dave
pulsar gtr
Car: NISSAN VEHICLES
Yes the crank shaft on the ca18de and the ca18det are the same, as well as the connecting rod bearings, mainbearings, oil pump, head, valves, the only difference between the two engines are the pistons low compression on ca18det and the injectors, 370cc on the ca18det.
i hope that helped.
PULSAR GTR
deej-79
Thats the stateside CA18de right?
pulsar gtr
all ca18de are the same whether they are in northamerica or in Japan, the japnese ca18de has different intake design, thats about it
PULSAR GTR
boost_boy
Don't forget the rods! The DET has beefier rods compared to the DE's.
pulsar gtr
yes yes the rods, thanks boost_boy
PULSAR GTR
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
and piston oil squirters
gore
Car: 93 240SX hatch (ca18det)
you guys missed his second question. balanced crank shaft, I'd like to know too how much does this usually cost?
iliketocrash
sorry if this is slightly off topic but every now and again i hear about the ca18det suffering from crank bearing failure.. is this common with all ca18dets or is it a result of the engine taking a severe beating?
boost_boy
Quote »sorry if this is slightly off topic but every now and again i hear about the ca18det suffering from crank bearing failure.. is this common with all ca18dets or is it a result of the engine taking a severe beating?[/quote] Any engine subject to abuse like this one will need more general maintenance like oil and filter changes on a regular basis. Before these engine get to the U.S., Canada, Australia or wherever, most don't know the extent of the abuse the motor has endured. A mere peek into the valve covers can give you a godd idea about the previous life of the engine. After 5 engines, I've never had a bad one nor have I ever had bearing failure and I treat my engines to a good trashing.
CA19DET
the DE doesnt have the mains girdle the DET has either..
chezina
deej-79 wrote:Also can anyone point me in a direction to possibly buy or have a Crankshaft balanced?
For a new one you could try your local ripoff artist (Nissan dealer), or Tomei Japan.If you can't find any, contact me i have a used one that i can sell, i could also arrange the needed machine work (regrinding and balancing). Shipping should be no problem i'm located in Europe also.:)
deej-79
Chezina,
I am definetly interested, if you could find out how much you would want after re-grind, and balance I would really appreciate it.
Nathan
When you balance a crank you should also have the rods, pistons, flywheel, pressure plate, and front pulley there too so they can balance everything individually and then balance it all together. JUST balancing a crank wont really work ;)
NeedCAforS13
Car: CA swapped S13 coupe
wait... i never heard of a difference between rwd DE and DET rods? Is this only true on FWD CA's or does a RWD CA18DE also have smaller rods than a RWD CA18DET?
Sean
boost_boy
RWD CA18DE's have the same rods as the U.S. CA18DE engines. All CA18DET engines have the bigger rods while the DE models have the skinnier versions.
chezina
deej-79 wrote:Chezina,
I have to find out the price on monday, can't get anyone now at the machine shop. LIke Nathan said it's best to have the front pully, flywheel and clutch cover balanced at once(we can work that out too if u want/need it). :) My email: [email protected]
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
or you could send it to drp or someone to have it kinfe-edged and balanced. they cost a small fortune though. i think it would be much cheaper to find a good machine shop to knife-edge it and balance it properly, though i dont know if they would be able to balance the whole piston/rod/crank assembly as one. with knife-edging you'd need a good oil pump i think, or some way of keeping the engine lubricated, since i hear engines with this done can starve under high-load.
- tim
- tim
r34 gtr
ok, sigh, he never said anything about knife-edging it. disregard 9/10 of my whole post then. must be all those shrooms making me think i see things that arent there.
- tim
themadscientist
Don't know about the SOHC 18s or the stateside DOHC by my Silvia's DE has the same rods as the DET, crank girdle as well but no piston oilers. The block could be drilled and tapped for the oilers though, the gallery is the same. Working with a CA20 at the moment I can tell you the rods be skinny :eek:
NeedCAforS13
crank girdle as well?! sweet :) My motor just got into Orlando, I'm gonna go pick it up this afternoon!!!
WELCOME BACK TMS!:D
Sean
boost_boy
So he finally sent you the motor, huh? Are you gonna open it up or just add-on and boost?
Dee
NeedCAforS13
headgasket, but thats it:)
oh and it looks pretty nice! I just finished putting it in my garage... Its got a p/s pump, but no A/C :( and it came without a flyweel (so no bolts for you Ian :() Ryan, I have your coolant elbow, but I left my tools at work so I can't pull anything off it right now!
AAAHHHH, I want to start taking it apart, but I have no tools :D oh well, tomorrow I guess...
Sean
boost_boy
Cool! Let me know what's in the oil pan! Need to know if there's a girdle in there.
Dee
NeedCAforS13
lol will do :) now sign on AIM!
Sean
