msaskin »
https://forums.nicoclub.com/msaskin-u13754.html
Sun Jul 25, 2004 8:11 am
As far as I know the Tomei stroker kit (and possibly the others as well) don't come with rods, so I'd assume they are designed to work with stock length rods.
For building up an SR20...the stock crank doesn't seem to have any problem holding the power. If you dig around on freshalloy you should be able to get the part number, but I know Nissan USA stocks (and dealers should be able to get) a brand new stock SR20DET crank. I believe the cost is around $400 or so, which isn't terribly bad.
~matt
