ard wrote:? read nissan repair manual first.undo the "main girdle" and it will be free.
not that simple.
heres a proper responce.
1. download the fsm in the stickies, look at the EM section.
things that will need to be removed.
crank timing gear(which can be a pita, my method is drill the gear tap it and use a timing gear puller) oil pump and pickup, rear main seal , gridle and main bolts.
thats a rough overveiw but should put u in the right direction.
