TheDrumAndTheBass wrote:...One thing a friend told me is that you don't need the chain guide, (see image, object b, indicated by the red arrow). Is there any truth to this. And if you don't need it, do you just remove the two bolts/posts that hold it on?Ryan
DON'T BELIEVE YOUR FRIEND!
The only reason I am opening up that nasty part of my car is because that guide (object b) has broken.
The chain rattles like crazy, and now that I have it apart I have witnessed the havoc it wrecked: The front cover has a 2" gouge about 1/8" deep in the area between where the two gudie bolts are. The chain was cuting away at the bottom bolt (since it wasn't removed, the guide only wore away around it).
And to top it all, the right (passenger) side guide has snapped too! I was probably only a few thousand km away from total engine failure all because the P.O.S. left chain guide was poorly designed and has been broken since forever (it was rattling when I bought the car 3 years ago).
Your friend was probably confused with the DOHC model where the top guide (between the two camshafts) can apparently be removed.
BTW, weren't you replacing the guide because it had broken? Or was it some other maintenance you were doing in there? If the left (driver's) side guide isn't broken, make sure it is the plastic-covered steel kind instead of the full-plastic kind , they are the faulty ones.
