huntin5L »
https://forums.nicoclub.com/huntin5l-u3755.html
Wed May 09, 2007 3:16 pm
As the title says, which puller should i get to take off the crankshaft pulley for my 90 sohc motor? The one with jaws, 6", 8"?? Or do i get the harmonic balancer pulley which is really what i think your suppose to use. I do kinda have a hard time believing your suppose to use the jaw puller, because the only place it looks like you can grab from is on the inner most pulley itself. Won't that mess up your pulley, won't it bend it? Also, there are 4 bolts on the inside of the pulley do I need to take those off too if i use the claw? Or should i take off those bolts and use the harmonic balancer puller? Let me know. Thanks, Bob.
Modified by huntin5L at 2:36 AM 5/10/2007
Modified by huntin5L at 3:42 AM 5/10/2007
Modified by huntin5L at 4:14 AM 5/10/2007
