crankshaft pulley
gumby
Car: '89 240sx sohc
the giant washer under the main pulley bolt is a little off center. and theres a small chunk missing where it was levered of the old engine. i asked a tech at the local nissan dealership if it would affect anything. he said it would unbalance the driveshaft. been that way for 20k. how much off a pain is it to get it centered.
the engines on a stand. i might be able to impact wrench it off but i know id have to mount the engine to get it torqued correctly.
is it worth it to get a new pulley because of the chip?
how much for a pro to do it?
Altiman94
Car: 1989 Nissan 240SX
I would get a new one. It's not hard at all to change them.
s13sr20chris
piece of cake to fix especially when on engine stand. you could always use the impact wrench to zap it back on instead of using a torque wrench but you did not hear it from me
gumby
Car: '89 240sx sohc
ok heres a pic. not sure if the camera angle is dead on but yuo can see its offcenter. how much of an issue is it?
s13sr20chris
wow, thats pretty noticable. what does the pulley look like when you pull it off?i think that will be a real balance issue at high rpm.is this a beater or a project?
gumby
Car: '89 240sx sohc
this is from a jasper remanufactured sohc with 20k
ill have the asp installed on this one
this mechanic was a slob
s13sr20chris
i think that is in fact a sloppy install job.
