crankshaft position sensor
lowblocks
Car: 1995 maxima
my car is giving a hard start so i pulled the code and it was the crank position sensor i cant find anything about it can some tell me about it how do i replace it and how much will it cost and can i do it my self?
maxhopper
Car: 02 Maxima SE 6spd
There are two crank sensors. One is just below the crank pulley, and the other is mounted between the bell housing and the engine block (near the radiator). Both are easy to remove/install.
What was the code?
lowblocks
Car: 1995 maxima
the code was 0407 but i was reading on the .org that if u have a bad starter your car will throw that code but since i got the car it always gave me a hard start but the car runs fine once it starts
maxhopper
Your code is for the sensor beneath the crank pulley.
lowblocks
Car: 1995 maxima
so what you think i should change the starter or change the sensor or do both and how do u think it will cost
maxhopper
Just to be on the safe side, I would pull the starter and have it tested at Autozone (or somewhere similar). If that checks out ok, replace the crank sensor. You should be able to find the sensor from one of NICO's sponsors for pretty cheap (try Pinnacle or Midway). It's held in by (I think) two 10mm bolts.
lowblocks
Car: 1995 maxima
so i bought the sensor for the passenger side is that the right one
maxhopper
Yes, according to the code.
03i35
Car: 2003 Infinity i35 (winter pkg)
zerothread?id=126327 check here my car had the same problem all i did was replace the CMPS bank 1 about $100 at infiniti of manhattan here. any questions contact me at [email protected]
