bartyb »
https://forums.nicoclub.com/bartyb-u13888.html
Sat Mar 24, 2007 1:15 pm
I bought another S14, and checking for codes, I've got the crankshaft position sensor code. The car was A/T at first and was converted to manual, so I'm assuming the previous owner used an S13 transmission without that sensor on the bellhousing as when I did the swap on my kouki I used the proper S14 transmission. My question is what does it change to run without that sensor, I know it's related to OBD, but the engine seems to run fine without it. So do I have to drill and install that sensor or is it pretty much useless?
Also, I got the knock sensors and O2 sensor codes (the 2nd one), so I'll be changing them too. About the 2nd O2 sensor, is it really necessary? The car still has the original exhaust, but my other S14 doesn't and it kept throwing codes (no more cat), so I'll be getting a O2 simulator for it. But other then not burning the optimal amout of fuel, is there any other repercussions on running without the 2nd O2 sensor?
Thanks.
