Crankshaft counterweights size Vs. main bearing wear questions.
Olderthanme
Car: 1974 260Z
Hi guys,I'm looking for some experienced opinions on light weight crankshafts.
How much weight should be counterbalanced to not have excessive bearing wear?I am working on an engine to rev quickly but I want there to be adequate counterweights as to not wear the main bearings out quickly. I have seen some race cranks that have very minimal counterweights but then when you look at OEM crankshafts there are huge counterweights. How do I determine the proper amount of counterweight needed as to not eat through the bearings instantly?
I am looking to spin this crank to 8500+ RPMs and would like to reduce the amount of rotating mass as much as possible but still be able to put miles on the engine.
Thanks guys!OTM
