CRANKS BUT WONT START UP
erasmo323
Car: 1989 NISSAN 240SX HATCH
1984 TOYOTA PICK UP TRUCK
1992 NISSAN 240SX COUPE
:ohno:
Found out that it was throwin codes
11 + Crank angle sensor circuit
34 Detonation sensor circuit
then i went and changed my distributor following the tutorial set it at top dead center and pointing rotor at #1 cylinder still no luck it'll crank but wont start....... so i tried setting the timing again two more times after that still no luck evn after i used some jumper cables to get more juice from the battery still nada........ changed spark plugs, spark plug wires, the distributor came off a running s13 cleaned my IACV im pretty sure im getting gas becasue i disconnected the line after the fuel filter and turned the ignition to ACC and fuel squirted out, im getting some spark too i disconnected every wire while cranking and grounded it im getting blue spark, uhmm i don't know what else to look for after that i checked the ECU for more codes and im getting 55 everything is OK!>!<?>?< o_0 HELP ANYBODY
CRANKS HARD BUT WONT START
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
It's possible that you have it set 180* off. Did you make sure that it was on the compression stroke when you were doing it?
erasmo323
Good point no I did not make sure it was in the compression stroke how would I be able to fix this?
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
quick and easy way is to pull a spark plug and when it's on a compression stroke you'll be able to feel some air coming out of the hole. Otherwise, you can pull the valve cover and look at the way the cams lobes are facing (I believe that facing away from each other is compression but I'm not positive)
erasmo323
sorry for the late reply but i tried that again and again...is it possible for it to be the coil next to the air box
