Statichardbodynoob »
https://forums.nicoclub.com/statichardbodynoob-u258589.html
Sun Nov 15, 2015 8:46 pm
Before I begin, I must state I'm not new to forums but I am to this particular one. That being said, I know how to use a search button and Google has been my friend for a long time. I have searched for awhile and can't find exactly my problem that has been solved. So here we go...
My 94 hardbody, ka24e 5spd, ran fine until one day it wouldn't start. No warning signs, just no longer getting spark. As I've worked on other cars all my life, I began troubleshooting. The distributor was swapped for a known working one, new cap, button to no avail. Swapped back to the other distributor since it obviously wasn't an issue but kept the new cap and button. Plug wires and plugs are new, I replaced the coil and ignition control module still nothing. The only trouble code it throws is 41 - Air temperature sensor circuit, which I've read is usually a bad MAF? But would this cause a no start condition involving no spark? All my fuseable links and connectors are fine, relay clicks everytime, I cleaned every ground I could find today, and had the battery tested at the parts store.
I'm pretty stumped, never had a vehicle be this stubborn starting. The battery is a pretty old optima. Even though it tested good out of the vehicle, it would still be possible that it's not giving enough juice with a load on it right? I had my battery charger on it for a few hours and attempted to start it, the charger dropped from 50% to 0. Seems like a huge pull, or the battery maybe shot to me but I'm guessing now. It turns over fine when the battery is charger but still no spark. I need to get another battery for my multimeter so I can see how many volts I'm getting when I'm cranking. I'm just running out of options with this truck and looking for some insight. Between school, work, and the wife and I are down to 1 car is limiting the time I even get to tinker with it.
Any help would be greatly appreciated.
