Cranks but wont run
JTerens
Car: 1989 nissan 240sx
So I'm lost on what is exactly wrong with my car now. the car cranks fine, new alt. new starter. new battery. new plugs. wires. car just wont turn over. I can get the car to start if i roll it in N and then throw it in gear, but it runs kinda rough. i dont have the slightest bit of timing on these cars. my plymouth laser on the other hand i knew everything...so if anyone could help i would appreciate it. i need this car as a DD for my new job
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
What is the story on the car before you bought these parts? Did it run? Did you take anything apart? Hard to help without more info.
Florida240sx
Got all your grounds??? Checked for vaccum leaks? MAFS?
JTerens
Car ran, buddy said it sounded like my fuel pump is out...replaced the cap n rotor, alt, battery, plugs, wires, filters. im hoping thats all it is, another friend said it could be the EGR causing this problem...i can push her down the street like i said and get her to start but other than that it just wont fire up...cranks and cranks but no go.
ELBORICUALOCO
JTerens wrote:So I'm lost on what is exactly wrong with my car now. the car cranks fine, new alt. new starter. new battery. new plugs. wires. car just wont turn over. I can get the car to start if i roll it in N and then throw it in gear, but it runs kinda rough. i dont have the slightest bit of timing on these cars. my plymouth laser on the other hand i knew everything...so if anyone could help i would appreciate it. i need this car as a DD for my new job
It sound like it might have jump time, need to with timing gun, then you can also check if the neutral safety switch on the trany(standard), but on the rough issue To me it jumped time.
