Justin35ll »
https://forums.nicoclub.com/justin35ll-u118020.html
Sat Dec 26, 2009 6:37 am
Did you put the voltmeter on the connector while someone was cranking it to see if it spikes to 12v when it's supposed to fire.Check for any loose connections on the harness. You said you already tried swapping out the ECU so it's gotta be something in the wiring or a timing issue.I'm actually not sure what the injectors are told to fire off of, I'm assuming the CAS
