blackRB240 »
https://forums.nicoclub.com/blackrb240-u97719.html
Thu Oct 30, 2008 7:11 am
Check the power and ground to the ECU. If you tapped into the stock harness, there should be a ground wire on the back of the motor, driver side, right under the valve cover. I know you said you have the Power FC unit, but every time a friend put a KA24de in their cars, they always skipped that step and the car won't give power to the fuel pump, distributor, coil, or injectors. Hope this helps.
