I've got a feeling it needs to be tapped out from the bottom. I may just not worry about it until the time comes to rebuild the motor later....tmorgan4 wrote:I tried to figure out how to get that piece out while mine was apart and I never got it out. It seems to be in there pretty well!
The tube/barel is steel not aluminum (not sure how it can be cast in), however I do think it's pressed in. I'll follow your advise and leave it alone and just clean up in place.Mettler wrote:Fairly sure it's cast into the aluminium... I wouldn't try remove it if I were you, just run a metal pipe cleaner through it and clean it in place (if you can)
