Touchdown038 »
https://forums.nicoclub.com/touchdown038-u3917.html
Tue Mar 28, 2006 8:49 pm
I've never had to do it, but from what I've heard from others, you undo the bolt on the bottom of the mounts and jack up the car under the oil pan. When it's up high enough you put a large socket under each mount and let the motor sit on those. It should be enough room to wiggle the oil pan out, provided you can break the seal while it's like this....
If someone else knows how to do this, please chime in.
