DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sun Jul 27, 2003 12:00 pm
2) YES!!! BIG ISSUE.
You have got to be careful here. I don't want to sound like an ***, but you really need to know what you're doing or you will bend your valves and you'll have to remove the head to replace them. Please stop all work and step back and think about how the valvetrain works. Even bolting down the camshafts if they're in the wrong place can cause a bending of the valves!Another thing is that the bearings you unbolt have to go back in the EXACT same location and orientations. If the camshaft is binding, it sounds like the bearings might be mixed up. They are match-honed to provide the bare amount of clearance required for oil passage while keeping all bearings in a straight line.You simply cannot replace camshafts unless you adjust for the different axes locations relative to the rockers. In other words, if you swap camshafts, you can NOT line up the timing marks and expect the valves to open at the right time or to not hit the pistons. Also, for all I know the bearing sizes might be different, and that might be why it's not fitting right. I'm certain that the lobes are shaped differently. You could not expect the car to run with 2 exhaust cams or 2 intake cams, even if you compensate for the offset axis timing.
