180fan »
https://forums.nicoclub.com/180fan-u3602.html
Fri Dec 23, 2005 3:37 pm
when mine stuck, I just poured motor oil over the sprocket and the shaft of the crank. Let it sit for a couple of minutes and start wiggling the sprocket around. It should pull right off. If not, try using using a screw driver behind it to get some leverage to make it move around a little bit.
Putting it back on is just push it back on.
