jacob360 »
https://forums.nicoclub.com/jacob360-u6512.html
Sat Nov 22, 2003 4:12 am
Its not an American car, use metric. Its 27mm. I just did a front crank seal in mine the other day.
Belt tension is something that comes with experience. There are gauges you can buy though. The 90 degree twist rule and feel are what I use. Do it on the longest span of the belt.
What are you going to use to hold the crank still while you loosen and tighten the crank shaft pulley bolt? I used a big chain wrench with an old piece of belt wrapped around the pulley to protect it.
