ILikeMy240sx »
https://forums.nicoclub.com/ilikemy240sx-u16757.html
Tue Nov 08, 2005 6:25 am
Put the ebrake on, put it in 5th gear. (Yes, 5th. because you want torque delivered to the wheels to be as less as possible so you dont move the car around) Get a breaker bar and hollow pipe if you have one to slip onto the breaker bar for extra leverage.
EDIT: just re-read your post... Oops sorry. Yea last time I did it, I stuck a bolt through the flywheel and the hole on the opp side and just used a breaker bar to loosen it.
