Crank sensor on s13 and s14.
kapitaljin
Car: 93 S13
I was searching on the FSM and realized that the crank sensor on the s13 is on the block and the s14 has it on the trans case (sensing the magnet from the flywheel).
Well here is what I am doing, I am swapping a s14 block into my s13 chassis.
Here is what I have:
-s13 manual ECU-S13 top and bottom harness (manual)-s14 block and trans with missing crank sensor.
Would it throw a code if I didnt put a sensor in?
I am unsure of what I need to do.
Thanks,
Eric
DALAZ_68
Car: 90' 240sx CA18det
no it wont...the s13 harness and ecu dont know about the s14 sensor...how can it throw a code for something its not registered to know is there
if ur using an s14 bkock
just get an s13 intake assembly and ur done and done...
kapitaljin
Car: 93 S13
Why the s13 intake assembly? I cant use my s14 intake manifold?
