the one right in front of the shifter on the top is the neutral switch.. the one under it is the speed sensor and the one with the hose off of it is the vent, it should mount to a metal u bend on the bell housing with on of the bell housing bolts. i dont think that the crank sensor is in the distributer i think its the cam sensor in there. could be mistaken. also a friend just put a s14 engine and transmission in his s13 and he had to switch the trannys over. said the drivelines wouldnt match up or somethingkapitaljin wrote:Also if you guys can help me out with this:
Modified by kapitaljin at 6:44 PM 4/14/2008
