That's what it is. I'm just doing this as a hobby. I would still like to take the engine apart so that I can learn about it. I just want to remove the heads so I can see the damages. Once I figure out how to remove that intake manifold then I can work on taking the heads out.J30tChumpCar wrote:Honestly just use this motor as practice, it is going to be garbage from sitting with a mix of oil/water everywhere. Everything you need to reuse in the rebuild (think camshafts) will have rust, you will spend double trying to rescue something that has not only the rust but prior to that had been compromised with heat (think about valve seats in 30,000 miles)
Finally got the lower plenum off, but it did not come off with the EGR and all the lines still attached. I also had to remove the back timing belt plate in order to pull it out. Now I can work on getting the heads off. The service manual doesn't really help much. It just says take off this and take off that but doesn't tell you how to do it. Any tips or instructions on removing the heads is much appreciated, otherwise I'll just try to figure it out. Thanks.NolimitZ32 wrote:If you have the upper plenum off yu should be able to unbolt the EGR inlet pipe from the DS (IIRC) manifold and the lowwer planum should come off with the EGR and all lines still attached. The actual EGR body is bolted by (Once again IIRC) 4 bolts to the back of the lower plenum.
I noticed I had to when I looked at it, but it didn't mention anything about it in the manual so I just went ahead and figured out how to remove it by removing the 2 pulleys.NolimitZ32 wrote:Its pretty obvious if you take the time to look that the rear timing cover needs to come off, granted the first time I took mine apart I ended up bending the isht out of it instead of doing it properly but I guess you live and learn. So are you saying the EGR is still in the car but the lower plenum is out?
WAIT! Those 2 big hex screws are NOT holding the heads on. They are just plugs. You have to take the 4 valve covers off first. Then down inside each head there are eight 10mm hex bolts that need to come off. Once you remove all 8 bolts from each side, there are 2 small 10mm bolts (not hex head, regular bolts) on the outsides of the head that need to be removed. The driver side head has this small bolt in the front corner, and the passenger side head has the small bolt in the outside rear corner. If you look where the head meets the block, you should find them.I see 2 big a** hex screws next to the spark plug holes which I'm assuming to remove the heads. I can't break that b**** loose and I don't want to break the bolt. Will need to buy another bottle or 2 of PB Blaster tomorrow. There seems to be a lot of space that I can get to now. There's more room to work with and now I'm wondering if I should just pull the engine out. I might have to do it after I remove the heads.
Thanks for the heads up. I would've wasted time taking those off if I could get them off because they wouldn't even budge. Back to the engine...t.mcginley.jr wrote:WAIT! Those 2 big hex screws are NOT holding the heads on. They are just plugs. You have to take the 4 valve covers off first. Then down inside each head there are eight 10mm hex bolts that need to come off. Once you remove all 8 bolts from each side, there are 2 small 10mm bolts (not hex head, regular bolts) on the outsides of the head that need to be removed. The driver side head has this small bolt in the front corner, and the passenger side head has the small bolt in the outside rear corner. If you look where the head meets the block, you should find them.I see 2 big a** hex screws next to the spark plug holes which I'm assuming to remove the heads. I can't break that b**** loose and I don't want to break the bolt. Will need to buy another bottle or 2 of PB Blaster tomorrow. There seems to be a lot of space that I can get to now. There's more room to work with and now I'm wondering if I should just pull the engine out. I might have to do it after I remove the heads.
Once all of those bolts are removed, you will probably need to hit the heads with a rubber mallet to get them to pop off. Once the heads are off, take the oil pan/oil pickup & pump off, then unbolt each rod cap from the connecting rods. Once removed, you should be able turn the block upside down and tap out the piston (with rod attached) with a hammer and piece of wood (think 1 foot of broom handle). Then you can take the main cap girdle off and remove the crank.
I can't really see where it's going, but I managed to get the exhaust manifold off instead so finally the other head is off. Such a relief. Time to take a break, then clean things up and then the block is next. Oh yeah.t.mcginley.jr wrote:You can't see where it goes from underneath the car?
It sounds like the oil return line that goes from under the turbo to the oil pan. If its not that then it's one of the coolant hard lines
