I’m about to put my underdrive pulley and realized I I lost the washer that goes to the big bolt. can I buy a grade 8 washer. What size washer and does any one know the thickness?
You can double up thickness using two if needed to hit the thickness if both are grade 8..........The OEM is generally not as hard, the thickness makes up for it.
