crank pully
92finityq45
Car: 1992 Infiniti Q45
could any one tell me what size the crank pully bolt is ?
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
I have an F50 in my bay now that has a 19mm I think the older ones are the same or a 22mm (most likely I will go explore to verify). You need to be very carefull when removing the 16 yo crank pulley so as not to break it.
Why are you removing it?
92finityq45
i just got a 92 q and 3 days later the guide broke when i tried to start it so im replacing them and i have a limited supply of tools at my hose i need to know what to bring home or buy.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Most stress on the timing chain is at initial start.
Get zip ties and read the threads in IOM. Tensioners are best replaced also, and verify that all the guide is removed.
92finityq45
my bubbieness is aboutto show, why zip ties and what is iom
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Ooooos! You are drowning!
Zip ties to hodl the timing chains.
Infiniti Online Mechanic
You have to do a lot of reading not to fubar the job. Losing timing or leaving guide material in the sump and not replacing the tensioners are the main killers of engines with new guides.
92finityq45
well the timing on the driver side was already lost the pass is still intact, can you put a link in to a thred that tells me how to retime the driver side. and how are zip ties going to keep the cams frome turning?
SteveTheTech
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
True it's not a real easy job to do in the driveway. It sucks to do in a bay in a shop I would not want to see how fun it would be anyother way.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Search on "timing chain guides" in IOM in post bodies and archived content. Several threads.
