I already put everything back and i was trying to set the timing. I didn't think that was right so i guess this is why the timing mark rotates counter clockwise when i have the timing light on it. I set the idle at 700rpm and even lower and the mark still moved but took forever to return to the top. Thats when i remembered about the pulley. I will get that off asap before it destroys all my hard work. Thanks for all your help evildky and everyone.evildky wrote:uh oh! nope it's not supposed to do that, sounds like your ballancer has gone bad, replace it! do not put that back on the car! you're gonna need a new ballancer
The problem is with the crank pulley on the center section where the a/c belt goes not on the pump but on the crank pulley.NORCAL300ZX916 wrote:on the ac pump or the crank pulley? the ac pump should do that. i dont understand how the main/crank pulley could spin with out being broken in two.
Should i get one or just find stock pulley. What is the advantage of an underdrive pulley?DanDrath wrote:time for an upgraded under drive pulley
although i have come across statistics stating losing 1lb of weight off the crank gains 2.4 hpbentandbuzzin wrote:Should i get one or just find stock pulley. What is the advantage of an underdrive pulley?DanDrath wrote:time for an upgraded under drive pulley
I heard the same thing about the lighter pulleys. I heard that the lighter weight can throw the crank off balance and possibly destroy the engine.NORCAL300ZX916 wrote:i was going to my local z specialist and he cautioned me against the underdrive pulley due to its lighter weight it lacks dampening ability. i guess it makes sense that you wouldnt want your main pulley to change speed even faster than it already does, wearing out belts faster.
You're just full of info. from now on your new name is professor evildky.evildky wrote:the stock crank pulley, aka harmonic ballancer has a membrane sepperating a weighted ring form the inner ring, this absorbs the natural harmonic of the engine and helps ensure a smooth idle and a long life
many ballanced race engines do nto run a ballancer and some cars do nto sue them, most honda's for instance
the power gained by an underdrive pulley comes in 2 ways, first reducing the rotating mass, this is actually a very small gain, low single digits, not enough to actually notice, second this smaller diamter slows down the accessories being driven, meaning your alternator water pump, power steering pump, and even a/c are spinning at a slower rate, this means they are not working as efficiently so that you can reduce the drag by another very small amount also not enough to feel, and the acessories are running at less than optimal speed but still within a reasonable range taht you won't miss the loss of cooling charging etc
if you watn a stock replacement I can sell you 1, $20 shipped in the US
hondas do use a balancer shaft to correct only having half a motor!evildky wrote:
Try asking someone thats running one if they are having problems, never heard of it causing issue even on moderate track cars.. oh a aluminum under-drive pulley saves not 1 or even 5 pounds it is 10+lbs lighter then stock!NORCAL300ZX916 wrote:i was going to my local z specialist and he cautioned me against the underdrive pulley due to its lighter weight it lacks dampening ability. i guess it makes sense that you wouldnt want your main pulley to change speed even faster than it already does, wearing out belts faster.
