Wings »
https://forums.nicoclub.com/wings-u56992.html
Wed Aug 01, 2007 8:52 am
Pulley kits are usually worth it. It may in fact give you a 30 HP increase. This may not be peak HP though so you may only see a couple HP increase overall. It's the same deal with intakes and exhausts. They advertise 10, 20 30 HP increases which technically may be true. It's just that it's not peak HP it will increase it more in other RPM's. These will always void your warranty due to the harmonic balancing. Whether internal or an external weight, the fact that it has been altered will definitely void the warranty. On the other hand, they have to prove the new part was the cause of the problem.
