180fan »
https://forums.nicoclub.com/180fan-u3602.html
Wed Sep 28, 2005 9:58 pm
Make sure your crank seal is the culprit. Sounds like your oil pump went dry as well with the fiasco, hence why your oil light was on for a while.
Otherwise, tighten the crank pulley to spec and it shouldn't fall off like that.
Now that you've heard the clank and ran the motor dry of oil, you should check to make sure you didn't spin any bearings. If you did, you're really gonna hate your life.
